This was already mentioned here:
opened 11:00PM - 05 May 23 UTC
### Describe the problem/bug
I am trying to install the Highcharts dependency… , after installing the dependency and restarting backend and frontend, it asks me to install Highcharts again. It doesn't seem to install.
### Versions:
- Mycodo Version: *8.15.8*
- ~Raspberry Pi Version~
- ~Raspbian OS Version~
- Intel computer with Ubuntu Server 22.04.2 LTS
### Reproducibility
Please list specific setup details that are involved and the steps to reproduce the behavior:
1. *Go to Setup -> Method*
2. *Click on Method Type and select Time/Data*
3. *Type the name and click on add*
4. *see install highcharts-9.1.2.js dependency - Click on Install All Dependencies*
5. *after installer, restart backend and frontend*
6. *Again go to Setup -> Method*
7. *Click on Method Type and select Time/Data*
8. *Type the name and click on add*
9. *Again requests to install highcharts-9.1.2.js*
### Expected behavior
*Install dependency and be able to add the Time/Data method*
### Screenshots
<img width="1132" alt="image" src="https://user-images.githubusercontent.com/49315112/236582029-80fad2f1-83e5-475a-80ef-e66b6b359f2d.png">
<img width="1133" alt="image" src="https://user-images.githubusercontent.com/49315112/236582060-23dfa291-80cd-44f7-8d18-a2e064f87b2b.png">
<img width="1159" alt="image" src="https://user-images.githubusercontent.com/49315112/236582096-3a5c0256-a2fd-4efd-b6b1-e8099b80210f.png">
### Additional context
1. Installing from the dashboard does not work either
2. Run the commands to see if it solves the problem, but it didn't work.
sudo mycodo-commands update-apt
sudo mycodo-commands update-dependencies
sudo mycodo-commands update-pip3
sudo mycodo-commands update-pip3-packages
sudo mycodo-commands update-permissions
sudo mycodo-commands upgrade-master
3. I tried deleting the .dependency file, but it didn't work.
thank you!
Previously, I was not able to replicate this behavior. However, I was able to replicate it today and come up with a fix. The latest release should resolve this:
