I have setup the low humidity conditional statement from the guide and the only thing I changed were the IDs associated with the humidity measure and the message. Any help would be greatly appreciated. I did find one post regarding a similar error but it did not seem to apply to me. Thanks in advance.
CODE:
humidity_too_low = 70
humidity_measure = self.condition("{d6d3a1ad}") # Latest humidity measurement
if humidity_measure and humidity_measure <= humidity_too_low:
#if humidity_measure <= humidity_too_low:
self.message += "Humidity is too low! Humidity is {} %".format(humidity_measure)
self.run_action("{aa19b321}", message=self.message) # Send email alert with current humidity
LOGS:
2021-11-24 11:23:30,104 - ERROR - mycodo.controllers.controller_conditional_0e095eef - Exception executing check_conditionals() on attempt 1 of 3. Waiting 10 seconds and trying again.
File “/var/mycodo-root/mycodo/controllers/base_controller.py”, line 124, in attempt_execute
func()
File “/var/mycodo-root/mycodo/controllers/controller_conditional.py”, line 182, in check_conditionals
self.conditional_run.message = message
AttributeError: ‘NoneType’ object has no attribute ‘message’
