If you raise the water from the water tank with a water pump, number 2 higher than number 1, so does the water go up from number 1 to number 2?
I don’t understand the question. Are you asking if the tube labeled 1 is the same tube labeled 2? If so, then yes, they are the same tube.
The water pulled up from the water pump is at the bottom and the plant bed is higher, does the water go up from the bottom?
