A01NYUB is an waterproof ultrasonic distance sensor from DFRobot. I use this to measure the water level in my main water tank. You can download the library and an example file through a GITHUB page. Library is in python and the example file also.
Since I am not a developer and not very keen with python programming and after a lot of tries to write a script to add the sensor in mycodo library through custom input with no luck (as instructions and example files proved not very helpful, to me at least), I came up with a workaround by using BASH Command input
If you face similar problem, here is what you have to do
First you need to make some changes.
Go to directory
“/home/username/DFRobot_RaspberryPi_A02YYUW/examples/” (replace username with username you chose when installing Raspbian)
Make a safe copy of the original file “demo_get_distance.py”
cp demo_get_distance.py demo_get_distance.py.bkp
then
sudo nano demo_get_distance.py
Delete all and Paste the following
# -*- coding:utf-8 -*-
@file demo_get_distance.py
@brief Get ranging data.
@n Connect board with raspberryPi.
@n --------------------------------------------
@n sensor pin | raspberry pi |
@n VCC | 5V/3V3 |
@n GND | GND |
@n RX | (BCM)14 TX |
@n TX | (BCM)15 RX |
@n
@Copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
@license The MIT License (MIT)
@author [Arya](xue.peng@dfrobot.com)
@version V1.0
@date 2019-8-31
@url https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW
import sys
import os
import time
sys.path.append(os.path.dirname(os.path.dirname(os.path.realpath(__file__))))
from DFRobot_RaspberryPi_A02YYUW import DFRobot_A02_Distance as Board
board = Board()
def print_distance(dis):
if board.last_operate_status == board.STA_OK:
print("%d" %dis)
elif board.last_operate_status == board.STA_ERR_CHECKSUM:
print("ERROR")
elif board.last_operate_status == board.STA_ERR_SERIAL:
print("Serial open failed!")
elif board.last_operate_status == board.STA_ERR_CHECK_OUT_LIMIT:
print("Above the upper limit: %d" %dis)
elif board.last_operate_status == board.STA_ERR_CHECK_LOW_LIMIT:
print("Below the lower limit: %d" %dis)
elif board.last_operate_status == board.STA_ERR_DATA:
print("No data!")
if __name__ == "__main__":
#Minimum ranging threshold: 0mm
dis_min = 0
#Highest ranging threshold: 4500mm
dis_max = 4500
board.set_dis_range(dis_min, dis_max)
distance = board.getDistance()
print_distance(distance)
Save and exit
These changes return one single value so mycodo can use store and display it.
Create a bash file in home directory for example. I named it A01NYUB.sh
Open it and Paste the following:
#!/bin/bash
python3 /home/username/DFRobot_RaspberryPi_A02YYUW/examples/demo_get_distance.py
save and close
from a termina run
chmod +x /home/username/A01NYUB.sh
And last step
on mycodo go to Setup/Input
Choose from the dropdown menu “Linux Bash Command: Return Value [Mycodo]”
In the window that opens
In Options section in the Command box paste
./A01NYUB.sh
In Custom options in the box User enter username you chose when installing Raspbian
And next to it in Current working directory type
/home/username/
click save ad then click close
Activate the input you just added
Done
P.S. I know this is basic knowledge to most of you but if I had this earlier It could have saved me a lot of time trying. I suggest that somehow it is a good start for a more detailed manual for beginners like me
