Hi, have tried to install the gauge widget and now the graph widget both of which did not complete.
The process stops after saving Highcharts-Stock-9.1.2.zip
See screenshots. What should I do?
Never seen this issue before. I’ll investigate, but in the future, copy the text rather than taking a screenshot. Screenshot text is unsearchable on the forum (for others having the same issue) and makes me have to type out the text to perform an internet search for a solution.
Ok, I will do so for any other issue that may come about!
Should I try to reinstall the whole system. That is Pi and Mycodo?
Now, finally I got it to work!
Previously when the dependency install failed I deleted the .depencies file and restarted the whole system, but the same error would occur again.
This time I only restarted front and back-end and afterwards it went through without trouble.
So now I can make use of those widgets.
