Hey there, I’m looking for confirmation on the wiring of ADS1115 for AC current sensing.
Going off of the main write-up which states:
Last, connect the negative and positive DC voltage outputs from this board to the analog-to-digital converter’s Ground and Analog 0 Input (A0) connections, respectively.
Wiring:
AC current Sensor |-> ADC |-> R PI 4
(-)negative |-> GND |-> GND
(+) |-> A0 |-> N/A
N/A |-> VDD |-> 5V
A |-> N/A |-> N/A
Traceback:
2022-03-08 09:21:16,193 - INFO - mycodo.controllers.controller_input_8307eded - Activated in 229.0 ms
2022-03-08 09:21:16,202 - ERROR - mycodo.inputs.ads1115_circuitpython_8307eded - InputModule.get_measurement() method raised IOError: [Errno 121] Remote I/O error
File "/var/mycodo-root/mycodo/inputs/base_input.py", line 116, in read
self._measurements = self.get_measurement()
File "/home/pi/Mycodo/mycodo/inputs/ads1115_circuitpython.py", line 159, in get_measurement
channel, self.adc_gain, chan.value, chan.voltage))
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_ads1x15/analog_in.py", line 61, in voltage
volts = self.value * _ADS1X15_PGA_RANGE[self._ads.gain] / 32767
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_ads1x15/analog_in.py", line 54, in value
return self._ads.read(
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_ads1x15/ads1x15.py", line 134, in read
return self._read(pin)
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_ads1x15/ads1x15.py", line 175, in _read
while not self._conversion_complete():
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_ads1x15/ads1x15.py", line 189, in _conversion_complete
return self._read_register(_ADS1X15_POINTER_CONFIG) & 0x8000
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_ads1x15/ads1x15.py", line 215, in _read_register
i2c.write_then_readinto(bytearray([reg]), self.buf, in_end=2)
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_bus_device/i2c_device.py", line 124, in write_then_readinto
self.i2c.writeto_then_readfrom(
File "/var/mycodo-root/env/lib/python3.9/site-packages/busio.py", line 183, in writeto_then_readfrom
return self._i2c.writeto_then_readfrom(
File "/var/mycodo-root/env/lib/python3.9/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 87, in writeto_then_readfrom
readin = self._i2c_bus.read_i2c_block_data(
File "/var/mycodo-root/env/lib/python3.9/site-packages/Adafruit_PureIO/smbus.py", line 275, in read_i2c_block_data
ioctl(self._device.fileno(), I2C_RDWR, request)
2022-03-08 09:21:21,233 - DEBUG - mycodo.inputs.ads1115_circuitpython_8307eded - Channel 0: Gain 0.6666666666666666, 0 raw, 0.0 volts
2022-03-08 09:21:21,245 - DEBUG - mycodo.inputs.ads1115_circuitpython_8307eded - Channel 1: Gain 0.6666666666666666, 0 raw, 0.0 volts
I tried various other configurations until I was able to get some feedback:
Wiring:
(+) |-> VDD |-> 5V
A |-> A0 |-> N/A
The above returned:
2022-03-08 09:42:03,717 - DEBUG - mycodo.inputs.ads1115_circuitpython_8307eded - Channel 0: Gain 0.6666666666666666, 106 raw, 0.01912558366649373 volts
2022-03-08 09:42:03,722 - ERROR - mycodo.inputs.ads1115_circuitpython_8307eded - InputModule.get_measurement() method raised IOError: [Errno 121] Remote I/O error
File "/home/pi/Mycodo/mycodo/inputs/ads1115_circuitpython.py", line 160, in get_measurement
measurement_totals[channel] += chan.voltage
2022-03-08 09:42:08,754 - DEBUG - mycodo.inputs.ads1115_circuitpython_8307eded - Channel 0: Gain 0.6666666666666666, 129 raw, 0.023250709555345316 volts
SDA and SCL connected, and i2C detected throughout.
I’ve looked through the wiring diagram, live image, and video recordings. The 3 show different or at times ambiguous set-up.
Please let me know if I can provide more info in solving this issue.
