My hydroponic system with Atlas Scientific sensors (pH, EC, temperature probe etc) was working well for several months. Then I took it out of commission to clean it, and it was a little while before I could get time to rebuild it - nearly 2 months. During this time I had my pH and EC probes stored with their tips in water (not ideal, I know, but I wasn’t expecting it to be such a long gap in operation.)
Anyway, I have put it all together again and I am not getting good results - I can’t get anything out of the pH sensor except 254 which according to page 46 of the manual, this means “still processing, not ready”.
I am using the sensors in i2c mode, and again - as far as I can tell, nothing has changed since the last time I had the system working. I am worried that the sensor itself has been damaged but I wondered if anyone else had had this issue.
The last lines of the /var/log/mycodo/mycodo.log are as follows (note i’m also getting this issue with the EC probe, though not consistently - occasionally it gets a reading.)
I got the same 254 responses direct from a python interpreter on the Pi, using smbus, so i don’t think its an issue with Mycodo. Thanks
2022-07-08 12:28:45,129 - INFO - mycodo.controllers.controller_widget - Activated in 184.6 ms
2022-07-08 12:28:46,131 - INFO - mycodo.daemon - Mycodo daemon started in 13.196 seconds
2022-07-08 12:28:46,338 - INFO - mycodo.daemon - 58.32 MB RAM in use
2022-07-08 12:28:58,761 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:29:18,795 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:29:38,784 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:29:58,812 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:30:18,777 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:30:38,733 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:30:58,783 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:31:38,812 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:31:58,780 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:32:18,728 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:32:38,765 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:32:58,804 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:33:18,756 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:33:38,814 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:33:58,756 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:34:18,825 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:34:38,780 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:34:58,814 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:35:18,749 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:35:38,788 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:35:58,750 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:36:18,795 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:36:38,739 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:36:58,794 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:37:18,729 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:37:38,821 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:37:58,810 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:38:18,777 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:38:38,835 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:38:58,791 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:39:18,746 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:39:38,788 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:39:58,755 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:40:18,801 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:40:38,768 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:40:58,809 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:41:18,758 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:41:38,826 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:42:18,793 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:42:58,808 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:43:18,774 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:43:38,757 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:43:58,812 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:44:18,746 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:44:38,792 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:44:58,736 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:45:18,813 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:45:38,785 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:45:58,736 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:46:18,971 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:46:38,803 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:46:58,818 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:47:18,755 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:47:38,821 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:47:58,783 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:48:18,692 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:47:21,563 - INFO - mycodo.daemon - Mycodo daemon v8.13.10 starting
2022-07-08 12:47:22,597 - INFO - mycodo.devices.atlas_scientific_i2c_1_105 - Atlas Scientific Board: PMP, Rev: 2, Firmware: 1.04
2022-07-08 12:47:22,597 - INFO - mycodo.outputs.pump_atlas_ezo_pmp_19abc25a - Initialized in 482.8 ms
2022-07-08 12:47:23,071 - INFO - mycodo.devices.atlas_scientific_i2c_1_104 - Atlas Scientific Board: PMP, Rev: 2, Firmware: 1.04
2022-07-08 12:47:23,072 - INFO - mycodo.outputs.pump_atlas_ezo_pmp_14291b56 - Initialized in 472.9 ms
2022-07-08 12:47:23,557 - INFO - mycodo.devices.atlas_scientific_i2c_1_102 - Atlas Scientific Board: PMP, Rev: 2, Firmware: 1.04
2022-07-08 12:47:23,557 - INFO - mycodo.outputs.pump_atlas_ezo_pmp_0decab3e - Initialized in 484.2 ms
2022-07-08 12:47:24,067 - INFO - mycodo.devices.atlas_scientific_i2c_1_103 - Atlas Scientific Board: PMP, Rev: 2, Firmware: 1.04
2022-07-08 12:47:24,068 - INFO - mycodo.outputs.pump_atlas_ezo_pmp_4d4d53c3 - Initialized in 502.3 ms
2022-07-08 12:47:24,068 - INFO - mycodo.controllers.controller_output - Activated in 2242.7 ms
2022-07-08 12:47:24,568 - INFO - mycodo.daemon - All activated Conditional controllers started
2022-07-08 12:47:24,569 - INFO - mycodo.daemon - All activated Trigger controllers started
2022-07-08 12:47:25,311 - INFO - mycodo.devices.atlas_scientific_i2c_1_99 - Atlas Scientific Board: pH, Rev: 2, Firmware: 2.14
2022-07-08 12:47:27,694 - INFO - mycodo.controllers.controller_input_f5291b66 - Activated in 2959.9 ms
2022-07-08 12:47:28,380 - INFO - mycodo.devices.atlas_scientific_i2c_1_100 - Atlas Scientific Board: EC, Rev: 2, Firmware: 2.15
2022-07-08 12:50:31,415 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:50:33,582 - INFO - mycodo.controllers.controller_input_9d7b1d8c - Activated in 4403.6 ms
2022-07-08 12:50:33,890 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 12:50:34,224 - INFO - mycodo.devices.atlas_scientific_i2c_1_101 - Atlas Scientific Board: RTD, Rev: 2, Firmware: 2.10
2022-07-08 12:50:35,737 - INFO - mycodo.controllers.controller_input_71aa2c36 - Activated in 1985.3 ms
2022-07-08 12:50:36,008 - ERROR - mycodo.inputs.atlas_ec_9d7b1d8c - Sensor read unsuccessful: 254
2022-07-08 12:50:36,117 - INFO - mycodo.controllers.controller_input_2f632bea - Activated in 244.1 ms
2022-07-08 12:50:36,494 - INFO - mycodo.controllers.controller_input_3c760159 - Activated in 288.4 ms
2022-07-08 12:50:36,494 - INFO - mycodo.daemon - All activated Input controllers started
2022-07-08 12:50:36,495 - INFO - mycodo.daemon - All activated PID controllers started
2022-07-08 12:50:36,495 - INFO - mycodo.daemon - All activated Function controllers started
2022-07-08 12:50:36,732 - INFO - mycodo.controllers.controller_widget - Activated in 237.0 ms
2022-07-08 12:50:37,734 - INFO - mycodo.daemon - Mycodo daemon started in 14.879 seconds
2022-07-08 12:50:37,738 - INFO - mycodo.daemon - 57.68 MB RAM in use
2022-07-08 12:52:32,296 - INFO - mycodo.inputs.atlas_ph_f5291b66 - Command: T,23.00
2022-07-08 12:52:32,603 - INFO - mycodo.inputs.atlas_ph_f5291b66 - Command returned: ('success', '')
2022-07-08 12:52:32,909 - INFO - mycodo.inputs.atlas_ph_f5291b66 - Stored temperature value: ('success', '?T,23.00')
2022-07-08 12:53:51,074 - INFO - mycodo.controllers.controller_input_f5291b66 - Deactivated in 27.4 ms
2022-07-08 12:54:07,712 - INFO - mycodo.devices.atlas_scientific_i2c_1_99 - Atlas Scientific Board: pH, Rev: 2, Firmware: 2.14
2022-07-08 12:54:10,114 - INFO - mycodo.controllers.controller_input_f5291b66 - Activated in 3051.7 ms
2022-07-08 12:54:10,467 - ERROR - mycodo.inputs.atlas_ec_9d7b1d8c - Sensor read unsuccessful: 254
2022-07-08 15:20:40,860 - INFO - mycodo.controllers.controller_input_f5291b66 - Deactivated in 34.2 ms
2022-07-08 15:20:54,173 - INFO - mycodo.devices.atlas_scientific_i2c_1_99 - Atlas Scientific Board: pH, Rev: 2, Firmware: 2.14
2022-07-08 15:20:56,554 - INFO - mycodo.controllers.controller_input_f5291b66 - Activated in 2848.4 ms
2022-07-08 15:21:28,840 - ERROR - mycodo.inputs.atlas_ph_f5291b66 - Sensor read unsuccessful: 254
2022-07-08 15:22:10,473 - ERROR - mycodo.inputs.atlas_ec_9d7b1d8c - Sensor read unsuccessful: 254
