Love your work on automated-hydroponic-system. I purchased an Atlas pH sensor for my Tower Garden, and I’m in the process of setting up some code to tinker with it via a Teensy 4.1 device, and I seem to be getting ph readings (in continuous mode). I have the EZO-pH circuit connected to electrically isolated carrier board, connecting TX/RX to my Teensy Serial1 pins and I’m getting numbers like 4.072, and if I switch the TX/RX I get nothing, so I’m pretty sure my default baud rate of 9600 is working ok. But it is not responding to any commands I send it like “status”, “C,0”, “i”, “name” or anything else listed in pH_EZO_Datasheet.pdf (atlas-scientific.com). Does it not respond to these commands until calibration is done? I don’t want to try calibration if the UART connection is not good first…
Looking at your code in atlas_scientific_uart.py I don’t see anything different from what I’m doing… is there some magic step need to get the device talking properly?
