Can Cytron Maker Pi Mycodo?
Hello I spent some time and learned a lot building a version of your product. I am running servo vent controls and and pwm l298n x 6.
I figured maybe some of this is already on 1 board. Found maker pi with 2 motor controls and 4 servo outlets and 7 sensor comports…
Maybe someone has used this maker pi and can explain if it’s useful for Mycodo?
I also saw this yahboom 6wd robot expansion card.
https://m.aliexpress.us/item/3256803316797626.html
Figured it has a lot of the puzzle on one board but I got no experience beyond copying your stuff.
Maybe there is already a robot control board with multiple motor drivers and pwm servo pins and maybe i2c inputs…
Mycodo is largely hardware agnostic. That is, you can use any hardware you want, as long as it can communicate with the computer running Mycodo and if there’s an output/input that already exists or one you create/import.
If you’re looking for something to do everything you want, you can either 1) buy individual components (breakout boards) and use only what you need, 2) buy a multi-purpose board and likely have more components than you need, or 3) make your own board with exactly what you need.
