I have this fella in my system which I try to integrate into Mycodo via ccs811_CP.py script. I get “Error 101: Device not set up. See Error Codes - Mycodo for more info.” each time no matter what I try but interestingly, I can get eco2 and tvoc values from the sensor with the same code when I try to initialize it in python terminal. It is enough for me to grab;
It works properly now even though I have changed nothing. I hope it keeps as in this way Btw, may I ask what is the appropriate way to sync the code changes in Mycodo? Is restarting the backend enough?
I again started experiencing my sensor not working meanwhile I can read data with the same code as Mycodo does from the terminal. I only get the error below about the sensor during the activation;
“ERROR - mycodo.inputs.ccs811_CP_70711835 - Error initializing, trying again in 5 seconds: Device returned an error! Try removing and reapplying power to the device and running the code again.”
