First of all, I am aware a similar question has been posted here before.(pH Data from Arduino to Pi (Mycodo)) However it didn’t really work in my case. I have three soil moisture sensors connected to my arduino. I managed to read serial data from the Arduino using a Raspberry Pi. But for some reason it doesent return any values in live measurements.
I used the following code as the python 3 v2 imput:
import serial
if __name__ == '__main__':
ser = serial.Serial('/dev/ttyACM0', 9600, timeout=1)
ser.reset_input_buffer()
while True:
if ser.in_waiting > 0:
line = ser.readline).decode('utf-8').rstrip()
moistlist123 = list(map(float, line.split()))
moistlist1 = float(sum(moistlist1))
return{0: moist1}
Obviously I am very new to python so please feel free to correct. If anything else could be the problem, some fixing-ideas would be great. Thanks!
Thank you. I honestly just mixed and matched. Which was probably a bad idea lol, since I have no experience with python. I am still struggling though. I tried editing the code based on your advice but got stuck on 4. Do you mind giving me an example of how the code could work?
#!/usr/bin/env python3
import serial
while True:
line = ser.readline().decode('utf-8').rstrip()
print(line)
Be sure to encase all code in backtics to properly format it. It’s impossible to read unformatted code that’s not monospaced.
This is properly formatted and uses the example code correctly. Whether it works is another matter.
import serial
import time
timeout = time.time() + 5
while time.time() < timeout: # exit if no measurement in 5 seconds
self.logger.debug(f"line = {line}")
return {0: line}
