Hi, Does anyone know if a module has been written for the SRF02 sensor I’m hoping to use it to monitor water level.
Regards
Chris
Regards
Chris
Hi Chris. There is not an input module for this sensor. The current list of supported devices can be found in the manual at Supported Inputs - Mycodo. It’s not difficult to create a custom input module. I recommend finding a similar input module for a distance sensor and modifying it to work with a Python library designed to read your sensor. If you look at the length inputs, you can see the last 3 utilize I2C sensors. These would be what I would base a new sensor on, since it should only require duplicating the file with a different file name, then changing input_name_unique, descriptive information, the Python library dependency, and the measurement code, at a minimum.
