Hello everyone,
I am setting up the DFRobot SEN0211 20A AC Current Sensor with Mycodo and an ADS1115 ADC.
I would like to configure it correctly in Mycodo, but I am not completely sure about the correct Input settings, scaling/equation, and calibration.
Could someone who is currently using the SEN0211 with Mycodo please share:
1. A screenshot of the complete Mycodo Input configuration for the SEN0211.
2. The ADS1115 configuration and which channel is being used.
3. The scaling / Rescale settings (Linear or Equation).
4. The equation or calibration formula you are using.
5. If possible, a photo of the physical wiring between the SEN0211 and ADS1115.
6. The voltage reading with no AC load connected.
7. The voltage reading with a known AC load running.
I am especially interested in seeing the actual Mycodo configuration screen and wiring, rather than only the general SEN0211 specifications.
Thank you very much for any help or photos you can provide.
