The EC PH control function does not work, I hope someone can help me
An EC range of 800 - 600 is irrational.
hmm ok Is the error in the values?
Yes, a valid range needs the lower value to be lower than the high value. The range variables are labeled high and low.
I don’t see any error and you also said it doesn’t work. Does it indeed not work?
Oops my mistake
I tested it works, thank you very much for your help, you are the best
