Electric valve with several ways?
Hello,
I want to use a pump that has a flow rate of 800L/h, instead of several mini pumps.
I wonder if there is an electric valve with several ways that I could control with a raspberry pi, choosing which way to water or choosing not to water anything. For each way there would be several plants that would be watered.
I am interested if you know if this exists and I am also interested if you have other ideas for doing this. I am available for more information.
Maybe you can use something like these?
https://a.aliexpress.com/_EQL3L80
Else you can use multiple valves and just open one at a time?
Most valves will only have a maximum of 2 outlets. As mentioned above, the easiest way to accomplish what you want to do is by using several single outlet valves attached to a manifold which is fed by your single pump. This is how most irrigation systems are designed.
Thanks for your answers, and sorry for my late reply.
I have decided to go with the manifold. I found the same one as in your photo : https://www.orbitonline.com/products/preassembled-manifold?variant=36386925772968
I just need to connect the different valves to a relay module and control the relay using a Raspberry Pi, right?
I was wondering if you could help me with an automatic ph dosser? All I need it to do is watch and ph up or down as needed. 5.8-6.2 range
