Enenrgy Usage (Amp Measure) Not working
I am using clamp current sensor via ADS1115 for current measurement on CH3. When I try to add this measurement for Enengy usage menu I get Error 404: Page not found
Thanks for the bug report. You must be running code from the master branch instead of the latest release. I just pushed a fix. You’ll need to upgrade to master again to get the latest code.
Thank you for quick update. It is working perfectly now. :grinning:
