Example of setting up a light timer?
I have mycodo setup and running. I am using a Kasa 6 outlet wifi controlled outlet strip and my environmental PID controllers all appear to be working.
Since I have a couple spare controlled outlets in the strip, is there an easy way to setup a light timer to control the environment lighting. I have searched and poked around a bit, but nothing jumps out at me.
Thank you,
-g
Yes, there are several timers in the Function dropdown menu. Duration, Daily Time Span, and Daily Time Point. You can also create any custom timer using a Conditional Function or a new Function Module that you can import from the Config page.
Thank you Kyle. Daily Time Span was exactly what I was looking for.
-g
