Hi Kyle,
In a Conditional Function, can I change the volume to be dispensed by a pump as needed? Thanks.
Tuan
Hi Kyle,
Tuan
Yes. Here is the description when you add the Volume Output Action:
[Action] Output: Volume: Instruct the Output to dispense a volume.
Usage: Executing self.run_action(“d6da6820”) will actuate a volume output. Executing self.run_action(“d6da6820”, value={“output_id”: “959019d1-c1fa-41fe-a554-7be3366a9c5b”, “channel”: 0, “volume”: 42}) will send a volume to the output with the specified ID and channel.
Hi Kyle,
Thanks for a quick reply.
I tried your way and it did not work. I got the message below:
My code:
self.run_action(“6e8ff642”, value={“output_id”: “959019d1-c1fa-41fe-a554-7be3366a9c5b”, “channel”: 0, “volume”: 100})
Error message:
2022-11-13 09:30:13,248 - ERROR - mycodo.action.output_volume_6e8ff642 - Error: Output with ID '959019d1-c1fa-41fe-a554-7be3366a9c5b' not found.
The code below runs the pump, but the dump does not dispense the correct volume, which is 100ml. As a matter fact, it always dispenses the same amount (the static value configured to be dispensed) even when I changed the volume:
value=‘{“output_id”: “959019d1-c1fa-41fe-a554-7be3366a9c5b”, “channel”: 0, “volume”: 100}’
self.run_action(“6e8ff642”, value)
Thanks for your help.
Tuan
output _id must be the ID of your output you want to manipulate, not the ID of the example I wrote. You can find this ID when you hover or click the output type button on the Output page.
It works. Thank you so much for your help.
Tuan
