Function: Multiple Outputs
Hi Guys,
I’m not sure if I just haven’t figured out how to do it yet, however I think it would be a great option if you could select multiple outputs for functions like PID.
Background: I have a humidification system in my greenhouse which consists of two actuators (nebulizer and fan).
However, both must be able to be addressed independently.
Currently this is not possible with a PID control (to my knowledge).
Regards
Just a shot in the dark, but it looks as if you are in need of a relay. It would allow you to connect multiple ouput devices and control them via I2c, Single wire, etc. There is a list of Function available to choose from to control the outputs.
I control these devices by a relay.
My suggestion for a new feature, means that you can set multiple outputs to act as a result of the function controller.
An Output Trigger Function enables you to trigger an output when another output changes.
I see says Stevie Wonder. That info just answered a post I created today! Thank you.
