awesome thanks!
Gave it a shot, but I can’t get it to work properly.
This is what I’ve configured:
So I want the UV light to come on for at least 10 seconds and then the Trigger must turn on plug 3 and 4.
Problem is that after 4 seconds the trigger is initiated. Even if I set the duration to 30, 60 or 90, it keeps coming on within 4 seconds. Please see below logs. I’ve tried the IF State (equal to duration) (greater than duration) (greater than or equal to)
Logs:
2022-07-28 18:16:16,292 - INFO - mycodo.controllers.controller_trigger_e0883381 - Activated in 1059.2 ms
2022-07-28 18:16:24,500 - INFO - mycodo.controllers.controller_pid_ac158eb2 - PID Settings: Device ID: 0fa712e8-251a-4608-874c-bd71ddec1c9b, Measurement ID: f44f9e22-3ff4-4af2-ae60-57276e2ef108, Direction: raise, Period: 120.0, Setpoint: 85.0, Band: 0.0, Kp: 3.0, Ki: 0.25, Kd: 0.0, Integrator Min: -100.0, Integrator Max 100.0, Output Raise: b7fb07d4-91db-4c2b-81cc-2c329325699b, Output Raise Channel: 1, Output Raise Type: on_off, Output Raise Min On: 15.0, Output Raise Max On: 0.0, Output Raise Min Off: 20.0, Output Raise Always Min: False, Output Lower: None, Output Lower Channel: None, Output Lower Type: None, Output Lower Min On: 0.0, Output Lower Max On: 0.0, Output Lower Min Off: 0.0, Output Lower Always Min: False, Setpoint Tracking Type: , Setpoint Tracking ID:
2022-07-28 18:16:24,505 - INFO - mycodo.controllers.controller_pid_ac158eb2 - Activated in 1041.7 ms
2022-07-28 18:16:54,874 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Latest (CH1, Unit: percent): 56.5089225769043 @ 2022-07-28 18:16:42
2022-07-28 18:16:54,877 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - PID: Input: 56.5089225769043, Output: P: 85.47323226928711, I: 7.122769355773926, D: 0.0, Out: 92.59600162506104
2022-07-28 18:16:56,839 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Setpoint: 85.0 Output: 92.59600162506104 sec to output b7fb07d4-91db-4c2b-81cc-2c329325699b CH1
2022-07-28 18:17:00,325 - DEBUG - mycodo.action.output_on_off_b9dfdeac - Message: 2022-07-28 18:16:57
[Trigger e0883381 (Trigger: Hum)] Output b7fb07d4-91db-4c2b-81cc-2c329325699b CH1 on_duration_equal_greater_than
[Action b9dfdeac, Output: On/Off/Duration]: Turn output 2ca6f016-ce92-4f43-831b-71d1e3a83944 CH2 (Kasa 6) on for 40.0 seconds.
2022-07-28 18:17:04,392 - DEBUG - mycodo.action.output_on_off_3602eb3f - Message: 2022-07-28 18:16:57
[Action 3602eb3f, Output: On/Off/Duration]: Turn output 2ca6f016-ce92-4f43-831b-71d1e3a83944 CH3 (Kasa 6) on for 20.0 seconds.
2022-07-28 18:17:48,476 - INFO - mycodo.controllers.controller_trigger_e0883381 - Deactivated in 120.7 ms
2022-07-28 18:17:54,483 - INFO - mycodo.controllers.controller_pid_ac158eb2 - Deactivated in 654.3 ms
If I set it to (equal to duration) then the trigger doesn’t initiate.
2022-07-28 18:27:26,154 - INFO - mycodo.controllers.controller_pid_ac158eb2 - PID Settings: Device ID: 0fa712e8-251a-4608-874c-bd71ddec1c9b, Measurement ID: f44f9e22-3ff4-4af2-ae60-57276e2ef108, Direction: raise, Period: 120.0, Setpoint: 85.0, Band: 0.0, Kp: 3.0, Ki: 0.25, Kd: 0.0, Integrator Min: -100.0, Integrator Max 100.0, Output Raise: b7fb07d4-91db-4c2b-81cc-2c329325699b, Output Raise Channel: 1, Output Raise Type: on_off, Output Raise Min On: 15.0, Output Raise Max On: 0.0, Output Raise Min Off: 20.0, Output Raise Always Min: False, Output Lower: None, Output Lower Channel: None, Output Lower Type: None, Output Lower Min On: 0.0, Output Lower Max On: 0.0, Output Lower Min Off: 0.0, Output Lower Always Min: False, Setpoint Tracking Type: , Setpoint Tracking ID:
2022-07-28 18:27:26,192 - INFO - mycodo.controllers.controller_pid_ac158eb2 - Activated in 2357.9 ms
2022-07-28 18:27:56,821 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Latest (CH1, Unit: percent): 53.23610305786133 @ 2022-07-28 18:27:42
2022-07-28 18:27:56,829 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - PID: Input: 53.23610305786133, Output: P: 95.29169082641602, I: 7.940974235534668, D: 0.0, Out: 103.23266506195068
2022-07-28 18:27:59,648 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Setpoint: 85.0 Output: 103.23266506195068 sec to output b7fb07d4-91db-4c2b-81cc-2c329325699b CH1
2022-07-28 18:29:56,689 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Latest (CH1, Unit: percent): 52.82392501831055 @ 2022-07-28 18:29:42
2022-07-28 18:29:56,704 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - PID: Input: 52.82392501831055, Output: P: 96.52822494506836, I: 15.984992980957031, D: 0.0, Out: 112.51321792602539
2022-07-28 18:29:58,998 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Setpoint: 85.0 Output: 112.51321792602539 sec to output b7fb07d4-91db-4c2b-81cc-2c329325699b CH1
2022-07-28 18:31:56,670 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Latest (CH1, Unit: percent): 52.1759033203125 @ 2022-07-28 18:31:42
2022-07-28 18:31:56,676 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - PID: Input: 52.1759033203125, Output: P: 98.4722900390625, I: 24.191017150878906, D: 0.0, Out: 122.6633071899414
2022-07-28 18:31:59,064 - DEBUG - mycodo.controllers.controller_pid_ac158eb2 - Setpoint: 85.0 Output: 122.6633071899414 sec to output b7fb07d4-91db-4c2b-81cc-2c329325699b CH1
2022-07-28 18:32:14,054 - INFO - mycodo.controllers.controller_trigger_e0883381 - Deactivated in 128.1 ms
2022-07-28 18:32:23,567 - INFO - mycodo.controllers.controller_pid_ac158eb2 - Deactivated in 2418.8 ms
