I just booted my mycodo after 6mth and updated to the latest release (It was like 15 releases behind). Everything seems to be working, except my 2 Seeed 4 channel i2c relay boards. I complains about the output channel not existing. I verified via i2cdetect that the boards are connected.
Here is the last 60 lines from the log
2022-07-15 09:36:58,343 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:37:58,423 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:38:58,430 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:39:58,393 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:40:58,340 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:41:58,375 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:42:58,344 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:43:58,453 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:44:58,476 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:45:58,395 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:46:58,326 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:47:58,406 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:48:58,415 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:49:40,904 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Cannot manipulate Output 1ee6161e-7631-4036-9574-86daf49c9dd9: output channel doesn't exist: 0
2022-07-15 09:49:58,457 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:50:58,479 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:51:53,713 - ERROR - mycodo.controllers.controller_output - Stopping output
File "/var/mycodo-root/mycodo/controllers/controller_output.py", line 189, in add_mod_output
self.output[output_id].stop_output()
File "/home/pi/Mycodo/mycodo/outputs/custom_outputs/grove_multichannel_relay_4ch.py", line 294, in stop_output
self.sensor.port(self.dict_to_list_states(dict_states))
AttributeError: 'NoneType' object has no attribute 'port'
2022-07-15 09:51:54,405 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - OutputModule did not overwrite the initialize() method. All subclasses of the AbstractOutput class are required to overwrite this method
2022-07-15 09:51:54,405 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Error initializing, trying again in 5 seconds:
File "/var/mycodo-root/mycodo/abstract_base_controller.py", line 54, in try_initialize
self.initialize()
File "/var/mycodo-root/mycodo/outputs/base_output.py", line 107, in initialize
raise NotImplementedError
NotImplementedError
2022-07-15 09:51:57,434 - DEBUG - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - output_on_off(on, 0, sec, 0.0, 0.0, True)
2022-07-15 09:51:57,434 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Cannot manipulate Output 1ee6161e-7631-4036-9574-86daf49c9dd9: output channel doesn't exist: 0
2022-07-15 09:51:58,355 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:51:59,412 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - OutputModule did not overwrite the initialize() method. All subclasses of the AbstractOutput class are required to overwrite this method
2022-07-15 09:51:59,412 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Error initializing, trying again in 5 seconds:
self.initialize()
NotImplementedError
2022-07-15 09:52:04,414 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - OutputModule did not overwrite the initialize() method. All subclasses of the AbstractOutput class are required to overwrite this method
2022-07-15 09:52:04,415 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Initialization errored 3 times; giving up. Maybe the following traceback can help diagnose the issue.
self.initialize()
NotImplementedError
2022-07-15 09:52:04,416 - INFO - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Initialized in 10692.5 ms
2022-07-15 09:52:13,960 - DEBUG - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - output_on_off(on, 2, sec, 0.0, 0.0, True)
2022-07-15 09:52:13,961 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_1ee6161e - Cannot manipulate Output 1ee6161e-7631-4036-9574-86daf49c9dd9: output channel doesn't exist: 2
2022-07-15 09:52:58,357 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:53:58,316 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:54:58,379 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:55:58,352 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:56:58,349 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:57:58,460 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
2022-07-15 09:58:58,355 - ERROR - mycodo.outputs.grove_multichannel_relay_4ch_612d6f7a - Cannot manipulate Output 612d6f7a-714b-4af0-8f86-14a4611c5198: output channel doesn't exist: 1
