Noticed the following error when attempting to reconfigure the ADS1256: Generic Analog pH/EC input module. Couldn’t see any errors in the source code and something I haven’t seen since upgrading mycodo.
The 7th positional argument it references was added back in July, so I’m not sure why you’re seeing that.
If this is some sort of custom module you imported and you’re not using the built-in module, then you may have issues when Mycodo updates and you don’t also update the custom module.
Ahh yes I had an old custom module with the same name that was interfering. Thanks!
