Is compatible the module hx711 from load cells with Mycodo?
Hello, i got two load cells with a module hx711, i want to add this sensors to the mycodo program.
I dont have so much knowledge about coding but i would like to start trying to add following the tutorial from the mycodo Page’‘How add new custom Inputs’’
Before start to configurate the template code i would like to know if Mycodo is compatible to add this module. Someone tried this before with or without success?
thanks for read
Hi! :waving_hand:
Yes — you can use an HX711 with Mycodo via a Custom Input. I recently worked on one and shared it here:
:link: Mycodo-custom/custom_inputs at main · wanoo/Mycodo-custom · GitHub
The ADS1256 is already on the Mycodo compatibility list and is a good 24-bit ADC for load cells.
Always a good idea to check the Mycodo documentation for compatibility before buying hardware…
