Hello there,
First of all I wanted to share my gratitude for this wealth of knowledge and all the work that has gone into creating Mycodo. As a software engineer, I certainly know and appreciate the energy it takes to get something like this productized and available to the community and wanted to say amazing job Kyle and all contributors ![]()
Total newbie to the cultivation world and just finished setting up an incubator and a fruiting environment controlled by Mycodo and for the most part it has been a super easy task with all the work being done by the software. I am having a problem I haven’t been able to get around yet relating to LCD. I have a SSD1306 LCD display that is recognized by the i2c scanner and is at the right address. But when I add it to Mycodo I get python errors complaining a method not found. Now the strange thing is that the LCD is configured as I2C but the error comes in from spi_device.py not i2c_device.py. This by itself seems strange (but I have to say I haven’t put any effort into understanding the architecture of the system top to bottom so that may totally be fine, just seems strange). Any suggestions on where to look/poke trying to figure this out:
2024-04-11 22:58:53,466 - ERROR - mycodo.function.display_ssd1306_oled_128x32_i2c_837fd6c9 - Error initializing, trying again in 5 seconds: name ‘DigitalInOut’ is not defined
File “/var/mycodo-root/mycodo/abstract_base_controller.py”, line 57, in try_initialize
self.initialize()
File “/home/morteza/Mycodo/mycodo/functions/display_ssd1306_oled_128x32_i2c.py”, line 378, in initialize
from mycodo.devices.lcd_pioled_circuitpython import PiOLEDCircuitpython
File “/var/mycodo-root/mycodo/devices/lcd_pioled_circuitpython.py”, line 5, in
import adafruit_ssd1306
File “/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_ssd1306.py”, line 17, in
from adafruit_bus_device import i2c_device, spi_device
File “/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_bus_device/spi_device.py”, line 29, in
class SPIDevice:
File “/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_bus_device/spi_device.py”, line 76, in SPIDevice
chip_select: Optional[DigitalInOut] = None,
NameError: name ‘DigitalInOut’ is not defined
2024-04-11 22:58:58,477 - ERROR - mycodo.function.display_ssd1306_oled_128x32_i2c_837fd6c9 - Error initializing, trying again in 5 seconds: name ‘DigitalInOut’ is not defined
self.initialize()
class SPIDevice:
2024-04-11 22:59:03,479 - ERROR - mycodo.function.display_ssd1306_oled_128x32_i2c_837fd6c9 - Initialization errored 3 times; giving up. Maybe the following traceback can help diagnose the issue.
self.initialize()
class SPIDevice:
2024-04-11 22:59:03,480 - DEBUG - mycodo.controllers.controller_function_837fd6c9 - loop() found
2024-04-11 22:59:03,480 - DEBUG - mycodo.controllers.controller_function_837fd6c9 - listener() not found
2024-04-11 22:59:03,480 - INFO - mycodo.controllers.controller_function_837fd6c9 - Activated in 10061.5 ms
2024-04-11 22:59:03,480 - ERROR - mycodo.function.display_ssd1306_oled_128x32_i2c_837fd6c9 - LCD not set up
2024-04-11 22:59:13,483 - ERROR - mycodo.function.display_ssd1306_oled_128x32_i2c_837fd6c9 - LCD not set up
2024-04-11 22:59:15,984 - INFO - mycodo.controllers.controller_function_837fd6c9 - Deactivated in 110.2 ms
