Lora 433mhz Waveshare Hat sx1268
Hello,
im thinking about implementing a SX1268 Hat and 433mhz Oultets to my Controller.
Im not a programmer so is that possible easily?
Will the listening code to sniff On/Off codes provided by Kizniche work with UART?
I would appreciate help from you guys im just a mushroom farmer who wants to automate shit as easy as possible.
Best Regards
hexxar
Can you be more detailed with links to everything you mentioned?
of course…
433mhz HAT SX1268 433M LoRa HAT - Waveshare Wiki
outlets https://www.amazon.de/gp/product/B001AX8QUM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I just want to trigger those outlets on/off depending on humidity and timebased lighting.
in my understanding i just have to have transmitter and receiver which should be possible with the sx1268. ?!
LoRaWAN is not the same communication protocol than the one used by those outlets. If you want to communicate via LoRa, you need outlets that support LoRa. Although the frequency may be similar (433 MHz vs 433.92 MHz), they do not use the same communication protocol.
Ah okay do you know Wireless Outlets with that Protocol?
Otherwise a good 433mhz hat with good Interference protection and good Range about 15m through Wall ?
Thanks For spending your time.
Okay i bought normal 433mhz transmitter receiver. Its working now. Thank you
Hi did you get your system working over lora?
