Hello,
I am using Mycodo version 8.16.2 on a Raspberry Pi 5 with a DHT11 sensor. However, Mycodo cannot read the temperature or humidity values — it only shows 0.
On a Raspberry Pi 4, the same DHT11 sensor works normally, but on the Pi 5 it does not.
• Mycodo version: 8.16.2
• Sensor: DHT11
• Hardware: Raspberry Pi 5
• Issue: Temperature and humidity always read as 0
Is there a known issue with DHT11 support on Raspberry Pi 5, or do I need additional configuration to make it work?
Thank you!
