I have tried to re-install Mycodo on a Raspberry Pi 4B 64-bit (influx V2).
Unfortunately, I have encountered an error and I have failed to find a solution.
The install failed at:
pip._vendor.pyproject_hooks._impl.BackendUnavailable: Cannot import ‘setuptools.build_meta’
I cannot login to Mycodo.
Here is the install error:
Collecting MarkupSafe==2.1.3 (from -r /opt/Mycodo/install/requirements.txt (line 26))
Downloading MarkupSafe-2.1.3.tar.gz (19 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
ERROR: Exception:
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/cli/base_command.py", line 107, in _run_wrapper
status = _inner_run()
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/cli/base_command.py", line 98, in _inner_run
return self.run(options, args)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/cli/req_command.py", line 85, in wrapper
return func(self, options, args)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/commands/install.py", line 388, in run
requirement_set = resolver.resolve(
reqs, check_supported_wheels=not options.target_dir
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/resolver.py", line 99, in resolve
result = self._result = resolver.resolve(
collected.requirements, max_rounds=limit_how_complex_resolution_can_be
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_vendor/resolvelib/resolvers/resolution.py", line 601, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_vendor/resolvelib/resolvers/resolution.py", line 434, in resolve
self._add_to_criteria(self.state.criteria, r, parent=None)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_vendor/resolvelib/resolvers/resolution.py", line 150, in _add_to_criteria
if not criterion.candidates:
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_vendor/resolvelib/structs.py", line 194, in __bool__
return bool(self._sequence)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 165, in __bool__
self._bool = any(self)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 149, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/found_candidates.py", line 39, in _iter_built
candidate = func()
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 180, in _make_candidate_from_link
base: BaseCandidate | None = self._make_base_candidate_from_link(
link, template, name, version
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/factory.py", line 226, in _make_base_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
link,
...<3 lines>...
version=version,
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 318, in __init__
super().__init__(
link=link,
...<4 lines>...
version=version,
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 161, in __init__
self.dist = self._prepare()
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 238, in _prepare
dist = self._prepare_distribution()
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/resolution/resolvelib/candidates.py", line 329, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/operations/prepare.py", line 543, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/operations/prepare.py", line 658, in _prepare_linked_requirement
dist = _get_prepared_distribution(
req,
...<3 lines>...
self.check_build_deps,
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/operations/prepare.py", line 77, in _get_prepared_distribution
abstract_dist.prepare_distribution_metadata(
build_env_installer, build_isolation, check_build_deps
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/distributions/sdist.py", line 55, in prepare_distribution_metadata
self._install_build_reqs(build_env_installer)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/distributions/sdist.py", line 132, in _install_build_reqs
build_reqs = self._get_build_requires_wheel()
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/distributions/sdist.py", line 107, in _get_build_requires_wheel
return backend.get_requires_for_build_wheel()
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_internal/utils/misc.py", line 694, in get_requires_for_build_wheel
return super().get_requires_for_build_wheel(config_settings=cs)
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_impl.py", line 196, in get_requires_for_build_wheel
return self._call_hook(
"get_requires_for_build_wheel", {"config_settings": config_settings}
File "/opt/Mycodo/env/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_impl.py", line 402, in _call_hook
raise BackendUnavailable(
...<4 lines>...
pip._vendor.pyproject_hooks._impl.BackendUnavailable: Cannot import 'setuptools.build_meta'
Collecting testfixtures==7.0.2 (from -r /opt/Mycodo/install/requirements-testing.txt (line 2))
Downloading testfixtures-7.0.2-py3-none-any.whl.metadata (3.4 kB)
Collecting mock==4.0.3 (from -r /opt/Mycodo/install/requirements-testing.txt (line 3))
Downloading mock-4.0.3-py3-none-any.whl.metadata (2.8 kB)
How can I fix this?
