8.14.0 (2022-08-13)
Bugfixes
- Fix inability to resume timelapses (#1163)
- Fix “Could not determine measurement from returned value” error for Atlas Scientific inputs
- Only increment the timelapse count when an image is captured
- Fix generating timelapse with custom file path (#1205)
- Fix timelapse filenames when using libcamera
- Fix printing lines on 2-line 128x32 SSD1306 Functions
- Fix PWM Slider Widget issues when Output signal is inverted and setting duty cycle
- Fix MCP3008 Input python library version number
Features
- Add ability to use Influxdb 2.x or Influxdb 1.x
- Add ability to set influxdb host and credentials in configuration
- Add Input: Raspberry Pi Power Monitor
- Add Input: MH-Z14 CO2
- Add Output: Non-SPI Neopixel
- Add ability to set Chirp Input I2C address (#1197)
- Add UI feedback for Atlas Scientific calibration commands (#1198)
- Add ability to use non-standard condition/action ID strings in Conditional Functions
- Add Websocket support to MQTT Outputs (#1219)
- Add Import and Initialize options to Conditional Functions (#1203)
- Add Input: MCP3208 Analog-to-Digital Converter (#1215)
Miscellaneous
- Add username/password requirements to Admin Creation page
- Move Conditional Condition text (#1204)
8.14.1 (2022-08-14)
Bugfixes
- Fix Conditional Function ‘timeout’ undefined error (#1220)
8.14.2 (2022-08-20)
Bugfixes
- Fix Kasa Plug Output (#1221)
- Fix Conditional Function not saving Import and Initialize Python Code
