After adding a USB Camera with OpenCV and starting a stream there no live video. Stopping the stream produces the following error. After this error the DS18B20 probe no longer reads temperature data. I was able to reproduce this error on a test system.
Error: Error stopping stream:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
- The Python version is: Python3.9 from “/var/mycodo-root/env/bin/python”
- The NumPy version is: “1.24.1”
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libcblas.so.3: cannot open shared object file: No such file or directory
