Odd disconnection
Hey kyle… I love this project man, been using it a lot.
I’m having the issue of my website going down after leaving the pi on for extended periods of time.
at first i thought it was an issue with wifi, when i pinged it i would return 50-25% packet loss, so i routed it to ethernet, and while it now loads between pages faster, ill still be unable to contact it if i leave the pi on for multiple days, even thought i am still able to ping it and see it is connected through my router.
The first thing that comes to mind is data corruption. It’s not uncommon if using an SD card. I now always recommend to run off a USB SSD for improved reliability.
okay, monitoring the °F i didnt think i’d of caused any damage cuz my pi has ran at a nice 120 for most of the time,
where can i find the files of mycodo so i can transfer to another SD?
Im having other odd problems as well, for instance i have my pi port forwarded, and when i log into my ipaddress:443 typing nothing else in, it’ll give me a bad http request, saying that i cant run an https thru http.
but if i type https:// prior to the ip, nothing will load
It may not be data corruption, it’s just what first comes to mind. Data corruption is just a natural process when using an SD card. SD cards were not designed for the number of read/writes an operating system performs and will degrade eventually.
You can backup and restore settings from the import/export page.
alright i believe ya, thank you very much sir have a good day
Did moving to an ssd work?
