I am attempting to build my first mycodo ph controller. The ph probe shows the current PH value in ‘live measurements,’ the ‘input,’ section of Mycodo, and also on my configured ‘dashboard’. I then configured two generic GPIO peristaltic pumps in the ‘Output’ section of Mycodo. From the output page I can turn on/off the pumps and I can do the same from the dashboard; this portion works without issue. I setup a bang-bang function to raise/lower the ph of the water with a .01 hyst targeted at 6.0. The function shows up in the Mycodo logs, but never turns on the pumps. Am I missing something?
2022-02-09 11:16:35,800 - INFO - mycodo.function.bang_bang_on_off_7eff7a25 - Input: 6.597201951027901, output_raise: off, output_lower: off, target: 6.0, hyst: 0.01
2022-02-09 11:16:39,771 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.610755747528582, ‘timestamp_utc’: None}}
2022-02-09 11:16:44,721 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.579925220003956, ‘timestamp_utc’: None}}
2022-02-09 11:16:49,768 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.76141434396872, ‘timestamp_utc’: None}}
2022-02-09 11:16:54,719 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.792993672201137, ‘timestamp_utc’: None}}
2022-02-09 11:16:55,663 - INFO - mycodo.function.bang_bang_on_off_7eff7a25 - Input: 6.792993672201137, output_raise: off, output_lower: off, target: 6.0, hyst: 0.01
2022-02-09 11:16:59,772 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.711208438423947, ‘timestamp_utc’: None}}
2022-02-09 11:17:04,717 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.8122343687447975, ‘timestamp_utc’: None}}
2022-02-09 11:17:09,764 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.714246198875217, ‘timestamp_utc’: None}}
2022-02-09 11:17:14,711 - DEBUG - mycodo.controllers.controller_input_1b327272 - Adding measurements to InfluxDB with ID 1b327272-4a37-4faf-ac27-fdc4876268da: {0: {‘measurement’: ‘ion_concentration’, ‘unit’: ‘pH’, ‘value’: 6.7612249417755335, ‘timestamp_utc’: None}}
2022-02-09 11:17:15,775 - INFO - mycodo.function.bang_bang_on_off_7eff7a25 - Input: 6.7612249417755335, output_raise: off, output_lower: off, target: 6.0, hyst: 0.01
