Pcf8575 issues with multiple outputs activating together
Has anyone else had issues with pcf8575
When set up, when any output is turned on outputs 9 - 16 all activate then every output works to turn them on and off individually until they are all off then any output turns outputs 9 - 16 all on again
What device are you using? Are you sure it’s wired appropriately?
