Publish Measurements with MQTT - Payload issue
i upgraded to mycodo 8.13.9. I’m receiving values from my sensor and try to publish them via MQTT (worked with an earlier version):
# Example code for learning how to use a Conditional. See the manual for more information.
#self.logger.info("This INFO log entry will appear in the Daemon Log")
#self.logger.error("This ERROR log entry will appear in the Daemon Log")
if not hasattr(self, "loop_count"):  # Initialize objects saved across executions
    self.loop_count = 1
else:
    self.loop_count += 1
temperature = self.condition("{4cb2d3cd}")
humidity = self.condition("{6c1f97c1}")
dewpoint = self.condition("{d53bc3be}")
vaporpressuredeficit = self.condition("{d526cfb5}")
temperature = "{:.2f}".format(temperature)
humidity = "{:.2f}".format(humidity)
dewpoint = "{:.2f}".format(dewpoint)
vaporpressuredeficit = "{:.2f}".format(vaporpressuredeficit)
self.logger.debug("Temperature published via MQTT {val}".format(val=temperature ))
self.logger.debug("Humidity published via MQTT {val}".format(val=humidity ))
self.logger.debug("Dewpoint published via MQTT {val}".format(val=dewpoint ))
self.logger.debug("Vapor Pressure Deficit published via MQTT {val}".format(val=vaporpressuredeficit ))
self.run_action("{b3974885}", temperature)
self.run_action("{c37dc071}", humidity)
self.run_action("{0ce5a183}", dewpoint)
self.run_action("{44ba2cb9}", vaporpressuredeficit)
now i get an bunch of unmatched format errors and “cannot publish without payload”
022-05-10 22:56:34,090 - ERROR - mycodo.function_action.mqtt_publish_b3974885 -  Error: Cannot publish to MQTT server without a payload.
2022-05-10 22:56:34,121 - ERROR - mycodo.daemon - Could not trigger Conditional Actions: unsupported operand type(s) for +=: 'NoneType' and 'str'
  File "/var/mycodo-root/mycodo/mycodo_daemon.py", line 977, in trigger_action
    return trigger_action(
  File "/var/mycodo-root/mycodo/utils/actions.py", line 339, in trigger_action
    message += "\n[Action {id}, {name}]:".format(
TypeError: unsupported operand type(s) for +=: 'NoneType' and 'str'
2022-05-10 22:56:34,154 - ERROR - mycodo.daemon - Could not trigger Conditional Actions: unsupported operand type(s) for +=: 'NoneType' and 'str'
2022-05-10 22:56:34,187 - ERROR - mycodo.daemon - Could not trigger Conditional Actions: unsupported operand type(s) for +=: 'NoneType' and 'str'
I tried publishing an static value, that worked. I did set the payload types to “Float / Decimal” because they were empty / “choose one”.
Any ideas what the issue is?
Thanks!
Hi Markus. Inputs can now have their own Actions added to them, which includes an MQTT Publish Action, so I’d suggest using that from the Input Configuration, rather than a function to publish measurements.
However, what you’re observing is a bug, and it’s resulting from not passing a string to the message parameter of the run_action() function. I just pushed a fix for cases where no message is passed:
Thank you very much!
I switched to the MQTT Publish Action directly at the Input level and it works great :slight_smile:
Thank you
Markus
