Hi, I was upgrading my RasPi Zero W instance and encountered this error. I’m invesitgating now but thought I’d share in case anyone had already seen it and knew a fix.
The Pi Zero has no peripherals attached - it’s just logging CPU/GPU temperatures now.
I’ll update when I learn more. Thanks for any help / troubleshooting tips you might have!
This error results from the dependency-checker not able to properly attempt to import “usb.core” because it has a period in the string. I need to develop a different method for performing this check, such as generating a file with the string “import {import_name}” and attempting to run that script rather than the current method that uses “importlib.util.find_spec(package)”:
