After installing Mycodo on rpi4 there is no temp readings (cpu- gpu)! is it Mycodo or my rpi4. New install with Bullseye lite.
This should be fixed in this commit and will be available in the next release:
Thank you for the Great Program, will wait to update with next release.
In the meantime, you can disable the GPU measurement and the Input should work, with the current release.
Confirmed! Again, Thank You!!!
