Setup- Function setting:
Is the explanation correct in the Vapor Pressure Deficit Regulation manual? Or is it capture image?
If it’s normal to operate the Exhaust Fan when the humidity is high, I think the capture is right
You are correct. Thanks, I’ll update the article.
