Hello again,
after connecting the SI1145 i get this error in Live measurements
Version: 8.14.2
Database: 07c7c8ebc195
Model: Raspberry Pi 3 Model B Plus Rev 1.3
Release:
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Firmware:
b’’
Error (Full Traceback):
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask/app.py”, line 2077, in wsgi_app
response = self.full_dispatch_request()
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask/app.py”, line 1525, in full_dispatch_request
rv = self.handle_user_exception(e)
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask_restx/api.py”, line 672, in error_router
return original_handler(e)
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask/app.py”, line 1523, in full_dispatch_request
rv = self.dispatch_request()
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask/app.py”, line 1509, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args)
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask_login/utils.py”, line 303, in decorated_view
return current_app.ensure_sync(func)(*args, **kwargs)
File “/home/pi/Mycodo/mycodo/mycodo_flask/routes_page.py”, line 852, in page_live
return render_template(‘pages/live.html’,
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask/templating.py”, line 148, in render_template
return _render(
File “/var/mycodo-root/env/lib/python3.9/site-packages/flask/templating.py”, line 128, in _render
rv = template.render(context)
File “/var/mycodo-root/env/lib/python3.9/site-packages/jinja2/environment.py”, line 1301, in render
self.environment.handle_exception()
File “/var/mycodo-root/env/lib/python3.9/site-packages/jinja2/environment.py”, line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File “/home/pi/Mycodo/mycodo/mycodo_flask/templates/pages/live.html”, line 3, in top-level template code
{% set help_page = [“Data Viewing - Mycodo”, _(‘Live Measurements’)] %}
File “/home/pi/Mycodo/mycodo/mycodo_flask/templates/layout.html”, line 384, in top-level template code
{%- block body %}{% endblock -%}
File “/home/pi/Mycodo/mycodo/mycodo_flask/templates/pages/live.html”, line 112, in block ‘body’
{%- if dict_units[dict_measure_units[each_meas.unique_id]][‘unit’] -%}
File “/var/mycodo-root/env/lib/python3.9/site-packages/jinja2/environment.py”, line 466, in getitem
return obj[argument]
jinja2.exceptions.UndefinedError: ‘collections.OrderedDict object’ has no attribute ‘uv’
