Hiya,
I bought the recommended TRRS connector for the Speed Control Board. However, the linked schematic shows an RJ45 connector.
Which pad on the board should be soldered to Pin 1 of https://smile.amazon.com/dp/B089222S84?
Thanks!
Hiya,
Thanks!
I don’t see a schematic. What are you referring to?
The Pin configuration is:
Pin - Pad
1 - GND
2 - 10V
3 - PWM
4 - TACH
Each pin number is stamped on the metal pin of the connector.
Thank you, Kyle!
The linked schematic to which I was referring was the “circuit designed by lemonsquash11” from OSH Park ~
