No. I just tried without the LTC4311 (sensor plugged directly into the pi) and it still doesn’t work. I should’ve done that before connecting the ethernet. I have switched my sensor over to AHTx0 in the input section after finding this post. I have switched the SDA and SCL wire and tried 5v and 3.3v with no luck
ValueError: No I2C device at address: 0x38
2023-11-10 00:47:18,865 - ERROR - mycodo.inputs.ahtx0_circuitpython_5ef70a89 - Initialization errored 3 times; giving up. Maybe the following traceback can help diagnose the issue.
Traceback (most recent call last):
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_bus_device/i2c_device.py", line 175, in __probe_for_device
self.i2c.writeto(self.device_address, b"")
File "/var/mycodo-root/env/lib/python3.11/site-packages/busio.py", line 207, in writeto
return self._i2c.writeto(address, buffer, stop=True)
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 60, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/var/mycodo-root/env/lib/python3.11/site-packages/Adafruit_PureIO/smbus.py", line 303, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_bus_device/i2c_device.py", line 181, in __probe_for_device
self.i2c.readfrom_into(self.device_address, result)
File "/var/mycodo-root/env/lib/python3.11/site-packages/busio.py", line 197, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=True)
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 67, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end - start)
File "/var/mycodo-root/env/lib/python3.11/site-packages/Adafruit_PureIO/smbus.py", line 170, in read_bytes
return self._device.read(number)
OSError: [Errno 5] Input/output error
File "/var/mycodo-root/mycodo/abstract_base_controller.py", line 57, in try_initialize
self.initialize()
File "/home/pi/Mycodo/mycodo/inputs/ahtx0_circuitpython.py", line 62, in initialize
self.sensor = adafruit_ahtx0.AHTx0(
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_ahtx0.py", line 49, in __init__
self.i2c_device = I2CDevice(i2c_bus, address)
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_bus_device/i2c_device.py", line 62, in __init__
self.__probe_for_device()
File "/var/mycodo-root/env/lib/python3.11/site-packages/adafruit_bus_device/i2c_device.py", line 184, in __probe_for_device
raise ValueError("No I2C device at address: 0x%x" % self.device_address)
2023-11-10 00:47:18,871 - INFO - mycodo.controllers.controller_input_5ef70a89 - Activated in 10247.5 ms
2023-11-10 00:47:18,873 - ERROR - mycodo.inputs.ahtx0_circuitpython_5ef70a89 - Error 101: Device not set up. See https://kizniche.github.io/Mycodo/Error-Codes#error-101 for more info.
