Hello, first Thanks Kyle. Amazing piece of software. The documentation and guides and hints and what not. Majestic, King Kyle!
However…
On the graphs, would it be possible to tag a specific value? Example below. I made this with a function. But it might be an easier way to do this for less stubborn people…
I would also want to make a Request for a feature. Namely water level. The hardware I use is one of these.
I made a function to handle it, but its fugly. 10+(x/2.311*100/3.333) 10 liters is the volume below indicator range. I run this on an adc1115 with some resistors and a 5v input, it ranges from 0.009 to 2.495v. Depending on water level/indicator. The stick has 0-180 ohm depending on location. Thus voltage changes if its measured between another set of resistors. It was a fiddle to figure the correct values out. It would simply be alot easier, if we could have a configuration page for it. “Bring the indicator to the bottom, and click the button [store value for low]. Bring the indicator to top, click button, collect value [store value for high]… How much water do you have while on low, vs on high?”
I had a third thing, but I lost it… Even if none of the above is of any interest. Still an amazing piece of software. Very well done. It really can’t be said enough times.
Anyone have any suggestions for improvements?
