What would you suggest the best way to approach changing EC and PH setpoints based on number of days. I am interested in trying this with our lettuce plants. (eg. first 15 days 6.0 ph 1.2ec then 6.2ph for 5 days then 1.4ec for remaining time.).
I thought of using trigger: daily time point to increase a variable and check against its value.
You will likely want to use the datetime python library to check if the current day falls between pre-set periods where you want certain conditions to be set. The following Python code (completely untested) is how I would approach it:
import datetime
conditions_range = {}
ph = {}
ec = {}
# Set date ranges
condition_range[1] = (datetime.datetime(year=2022, month=6, day=1),
datetime.datetime(year=2022, month=7, day=1))
condition_range[2] = (datetime.datetime(year=2022, month=7, day=2),
datetime.datetime(year=2022, month=8, day=1))
condition_range[3] = (datetime.datetime(year=2022, month=8, day=2),
datetime.datetime(year=2022, month=9, day=1))
# Set pH and EC based on ranges
ph[1] = (5.9, 6.1)
ec[1] = (1.1, 1.3)
ph[2] = (6.1, 6.3)
ec[2] = (1.1, 1.3)
ph[3] = (6.1, 6.3)
ec[3] = (1.3, 1.5)
# Find current range
range_found = False
for i in range(1, 4):
if condition_range[i][0] < datetime.datetime.now() < condition_range[i][1]: # If current date falls within range
range_found = i
break
# Check if range has been found
if not range_found:
self.logger.error("Could not find range")
else:
self.logger.info(f"Found Range index: {range_found}: pH: {ph[range_found]}, EC: {ec[range_found]}")
# Code to regulate pH and EC goes here
This could also be a good use for a Date Span Function, which will execute actions when between two specific dates. You could then automatically activate a different Function for each date range.
It’s a bit of a bulky solution since you’ll need to duplicate a Conditional Function, rather than using one Conditional Function, since there’s currently no simple way to pass data to a Conditional Function.
This is also making me think about dedicated pH and/or EC Functions that allow a variable number of setpoints that can have date ranges associated.
Hi Kyle,
Thanks for those options. I was thinking of what a front end (end user) on a Pi screen in a greenhouse could look like. Maybe even to the point of being able to select crop a from custom database.
Have found changing the nutrient mix to grow, bloom and boost stages of lettuce makes a huge difference with time to harvest and quality of produce.
Thanks.
