Mosquitto MQTT broker does not restart after altering the config file
I have installed the Mosquitto MQTT broker on my Pi as per this tuturial:
https://randomnerdtutorials.com/how-to-install-mosquitto-broker-on-raspberry-pi/
After altering the config file to enable user names and password authentication I’m getting this error when restarting the broker:
ko@raspberrypi:~ $ sudo systemctl restart mosquitto
Job for mosquitto.service failed because the control process exited with error code.
See “systemctl status mosquitto.service” and “journalctl -xeu mosquitto.service” for details.
Here the ouput from the two logs suggested:
ko@raspberrypi:~ $ systemctl status mosquitto.service
× mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Tue 2024-02-27 20:15:13 +07; 29min ago
Duration: 1w 2h 12min 30.372s
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 185416 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 185417 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 185418 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 185419 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 185420 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 185420 (code=exited, status=1/FAILURE)
CPU: 27ms
Feb 27 20:15:13 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Feb 27 20:15:13 raspberrypi systemd[1]: Stopped mosquitto.service - Mosquitto MQTT Broker.
Feb 27 20:15:13 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
Feb 27 20:15:13 raspberrypi systemd[1]: mosquitto.service: Failed with result ‘exit-code’.
Feb 27 20:15:13 raspberrypi systemd[1]: Failed to start mosquitto.service - Mosquitto MQTT Broker.
ko@raspberrypi:~ $ journalctl -xeu mosquitto.service
░░ Subject: A start job for unit mosquitto.service has failed
░░ Defined-By: systemd
░░ Support: Debian -- User Support
░░ A start job for unit mosquitto.service has finished with a failure.
░░ The job identifier is 37624 and the job result is failed.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit mosquitto.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
░░ Subject: A stop job for unit mosquitto.service has finished
░░ A stop job for unit mosquitto.service has finished.
░░ The job identifier is 37702 and the job result is done.
░░ Subject: Unit failed
░░ The unit mosquitto.service has entered the ‘failed’ state with result ‘exit-code’.
░░ The job identifier is 37702 and the job result is failed.
Can anyone identify what the issue is here?
Basic troubleshooting questions, sorry if I’m being too basic…
Did it start up and work properly before setting up the username and password?
If you change “allow_anonymous” to true (in /etc/mosquitto/conf.d”) will it start?
My .conf file on the Mosquitto broker that I’m using a username and password on is shown below, if that helps.
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
allow_anonymous false
listener 1883
password_file /etc/mosquitto/pwdfile
I found it. Apparently the listener port 1883 was being used by some other service. I have no idea which. After changing it to 1884 mosquitto restarts normally again.
Found this while having the same problem in Dec 2024 - mosquitto service wouldn’t start.
fyi - my config file was just like Billjuv’s above, but I had it in the /etc/mosquitto/conf.d folder. When I moved it up to the /etc/mosquitto folder the service started and works like a charm.
Cheers
